Date/Time: Sat, 01 Mar 2025 12:51:53 +0000
Commissions not included in trade exports
View Count: 373
[2021-10-05 12:09:40] |
User61576 - Posts: 445 |
The commissions are not included when exporting the trade or the stats. I am using s_acstrade stucture to export the trades through a study into a csv, all the other fields are working fine but the commissions. It's showing commissions as zero and is not considering it in the calculation of profit and loss of the trade. Why is that?
Date Time Of Last Edit: 2021-10-05 12:10:07
[2021-10-05 23:01:31] |
Sierra_Chart Engineering - Posts: 18607 |
Check this Chart Setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-05 23:01:43
