Date/Time: Sat, 01 Mar 2025 12:51:14 +0000
Infinity & Denali
View Count: 904
[2021-10-05 10:46:10] |
User120666 - Posts: 46 |
Hi, So if I open a future's account with Infinity Futures (and fund it), am I then able to access the cheaper CME data via Denali, but then trade through the charts using Infinity? If so, how do I setup separate data and trading within the Global Data Seetings? Thanks! |
[2021-10-05 17:19:29] |
John - SC Support - Posts: 38292 |
Yes If so, how do I setup separate data and trading within the Global Data Seetings?
You would follow these instructions to setup your connection to Infinity/TransAct: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Then you would follow these instructions to setup your Denali Exchange Data Feed for the CME Group data (if you need data for EUREX or CFE, those instructions are on the same page, just in a different location on the page): Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Then, just to ensure that everything is setup properly, you would go through these instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-06 02:12:38] |
User670721 - Posts: 2 |
If I have an Infinity account with Denali Data Feed - do you know if I can also trade from the InfinityAT PC-based DOM? (can Denali feed this?) Or would this require a second separate data feed via Infinity? |
[2021-10-06 14:32:28] |
The Sierra Chart data feeds only work with Sierra Chart. Therefore, if you are wanting to trade from the InfinityAT software, you would have to pay for a separate data feed to that system.
