Date/Time: Sat, 01 Mar 2025 11:21:32 +0000
Can't load historical intraday data completely
View Count: 682
[2021-10-05 07:38:14] |
User798274 - Posts: 14 |
Hi, I've been trying to download intraday data from 2010 to now in UB-CBOT. Even though the instrument was introduced somewhere around January 2010, I can't seem to figure out how download data beyond 2013-11-04. Is there a limit set by Sierra Chart or am I doing something wrong? The same goes for TN-CBOT. The instrument started trading on 01/11/2016 and I can see the whole data in a daily chart. When trying to download intraday data though it only goes up to 07/18/2016. Date Time Of Last Edit: 2021-10-05 07:39:55
[2021-10-05 09:00:37] |
If that is as far back as you can go for those contracts, that is all the data that is available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-05 09:00:45
