Date/Time: Sat, 01 Mar 2025 16:09:30 +0000
Problem connection Rithmics
View Count: 502
[2021-10-05 02:57:31]
Nonospinal - Posts: 3
I can’t connect to rithmics since last Friday, the download of the history is done correctly but I can’t trade and the status remains waiting to reconnect.
But if I use the connection with CQGWeb Api it works very well( in data/trade service setting)
Do you have any idea what the problem is ?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=55586
[2021-10-05 16:57:59]
John - SC Support - Posts: 38292
The only thing we can suggest is to use a different server selection. It looks like the one you have chosen is not setup properly from Rithmic.
[2021-10-11 00:19:51]
Are you still having an issue with this?
