Date/Time: Sat, 01 Mar 2025 12:57:52 +0000
Volume By Price Study
View Count: 515
[2021-10-04 23:05:33] |
Robert Wojczak - Posts: 148 |
When using the Volume By Price study I want to have a 5 day rolling Volume Point of Control (not including weekends)... for futures starting from 6pm on the re open what are the setting for this.. Thank You
[2021-10-05 16:30:21] |
John - SC Support - Posts: 38292 |
First, you would have to get your chart setup as you want it for the 5 day periods (we are not sure exactly how you want this setup). Then when you are setting up your Volume by Price profiles, you would use the following Inputs - Draw Mode: Volume Profiles & POC, VAH, VAL, VWAP - Volume Graph Period Type: Multiple Profiles Based on Fixed Time - Time Period Type for 'Fixed Time': Weeks - Calculate Developing POC and Value Areas: Yes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 16:43:45] |
Thank you I will try that
