Date/Time: Sat, 01 Mar 2025 13:11:16 +0000
Duplicate fills with IB service
View Count: 506
[2021-10-04 19:38:02] |
tomas262 - Posts: 145 |
hello guys, can you please advise why I get duplicate fills in the TAL? See the screenshot Date Time Of Last Edit: 2021-10-04 20:25:23
Private File |
[2021-10-06 03:37:35] |
There is an interactive brokers specific setting in Global Settings >> Data/Trade Service Settings to disable the downloading of order fills from TWS. Set that so that the order fills are not downloaded. And then you can remove the duplicates as explained here by deleting individual entries: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
