Date/Time: Tue, 26 Nov 2024 02:05:38 +0000
Gap in data for SC real time feed
View Count: 1205
[2014-03-26 20:47:23] |
User12676 - Posts: 70 |
Goes from 12-12 to 3-14. Where is all the missing data?
screen.jpg / V - Attached On 2014-03-26 20:46:53 UTC - Size: 87.19 KB - 399 views |
[2014-03-26 21:25:29] |
Looks like you are missing the March 2014 contract. Re-download the data following the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-26 21:26:04
