Date/Time: Sat, 01 Mar 2025 10:56:29 +0000
Trouble setting up MBO - having followed documentation.
View Count: 393
[2021-10-04 15:40:28] |
UnknownQuantity - Posts: 3 |
Hello, I don't want to be a pain, but I can't get the MBO to show in the DOM. I am sure this has been answered many times, but couldn't find an answer. I am on the $46 plan. I have the latest version of SC. I did follow the documentation re MBO, went into the server settings, (entered a number higher than 10), and disconnected, but still only get two levels in the DOM (Bid Size or Ask Size). Your help or suggestions are much appreciated. Thanks, Michael |
[2021-10-04 17:46:08] |
John - SC Support - Posts: 38292 |
You do not have any exchanges active that include the Market Depth data. You need to have that as well. You can change your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Just be aware that whenever you activate an exchange, you will pay the full amount for the remainder of the month in which you activate it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
