Date/Time: Sat, 01 Mar 2025 11:08:33 +0000
Sierra account data feed
View Count: 401
[2021-10-04 15:23:54]
JanTheMan - Posts: 4
i have live account in amp and use rithmic and jigsaw daytrader for execution and wish it would stay that way. I have a question because I would like to use Sierra for analysis and also have access to the real date. How to do it all? I should buy denali data but do you need to verify my account with amp first?
[2021-10-04 17:33:29]
John - SC Support - Posts: 38292
First, you need to get setup with a Sierra Chart package. Refer to the instructions here:
Sierra Chart Purchase and License Information: Instructions
Then, the thing to keep in mind is that to get the real-time data from us for the CME Group, you will need to connect to your live trading account at AMP. Therefore, you will need to do the following:
1) Setup the Denali Exchange Data Feed following these instructions:
If you need data for the EUREX or CFE, then instructions for those are on the same page for the Denali Exchange Data Feed.
2) Follow the instructions at the following link to connect to your AMP account to validate your account:
In Step #3 of the above, it tells you to connect to your trading account. In your case, since that is with CQG, you will follow these instructions:
CQG Trading Platform Service: Setup Instructions
