Date/Time: Sat, 01 Mar 2025 11:31:07 +0000
connection to CQG is not working
View Count: 614
[2021-10-04 15:22:41]
User955072 - Posts: 2
My connection to CQG is not working anymore and my rights are still active but my longon unsuccessful, can you do something. Thanks
[2021-10-04 17:24:02]
John - SC Support - Posts: 38292
If you are getting a specific message, then refer to the information at the following link which gives the information for many of the messages from CQG:
CQG Trading Platform Service: Common Error Messages
If you are getting an error message that is not listed in the above, then let us know the exact wording of the message.
If it is something else where you are not getting a message, then get us your message log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
