Date/Time: Tue, 26 Nov 2024 00:58:49 +0000
Where to set "LimitTouchChase" as primary order (entry order)?
View Count: 1141
[2014-03-26 19:24:56]
User24489 - Posts: 12
Hi Support,
How can i make the trading dom submit the entry as LimitTouchChase? I have only been able to get it to submit a LimitChase but, i don't want it to chase until it touches (if no fill).
Can you point me to the setting?
It says "This order can be submitted as both a main/primary order.." here > http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#LimitTouchChase
Thank you.
[2014-03-26 20:23:31]
I've looked around at the documentation more and i hope you're not going to tell me that only the LimitChase can be submitted from the DOM right now for the entry order.
When i click the "Chase" box on the MAIN tab it asks:
"Do you wish to submit Limit orders as Limit Chase orders?"
Is there a way for it to ask for either "Limit Chase" or "Limit Chase Touch" order or can a new setting be added to the next release to make the choice for this setting selection to be either "Limit Chase" or "Limit Chase Touch?
Please advise. Thank you.
[2014-03-27 18:57:43]
Bump for answer from support please..
[2014-03-28 07:57:29]
Right now, the Limit Touch Chase can only be submitted directly from the Trade Window, not the chart DOM, or used as an Attached Order.
