Date/Time: Sat, 01 Mar 2025 11:21:50 +0000
Problem with volume indicator when showing ETH
View Count: 531
[2021-10-04 15:13:03] |
ruby_kinetix - Posts: 24 |
hi Sierra , I use Volume bar on main chart, then Volume / number trade, and Up/ Down Volume difference bars. When the window only show RTh, all are showing normal, but when include ETH, those two volume indicators are just unreadable, how to handle this? I attached the problem in screenshot https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=55430 |
[2021-10-04 16:56:44] |
John - SC Support - Posts: 38292 |
The study Volume / Number of Trades did not have a check for zero trades, which then caused the problem as there was one bar that had no trades (we do not know why the data shows this, as it really does not make sense with a Volume bar chart, but that is what it is). We have fixed the study, so this will be in the next release to have that data show as a 0 when there are no trades. When the next Pre-Release comes available (v 2318), you can update using the Fast Update option. Refer to the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
