Date/Time: Sat, 01 Mar 2025 12:53:24 +0000
Connection Error
View Count: 563
[2021-10-04 15:12:36]
User956379 - Posts: 27
Dear Sierra Chart Support,
When starting Sierra chart I get the error message since yesterday: "Connection error message from service SC/TT Futures Order Routing Connection error: Trade account not assigned". What does that mean? Until the end of September, everything was still working normally.
[2021-10-04 16:47:56]
Sierra_Chart Engineering - Posts: 18607
We are checking on this.
[2021-10-04 16:50:57]
We are not observing any problem with this. Provide us the message log as explained below.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2021-10-04 16:52:28
[2021-10-04 18:19:39]
I send the Log with the Button "Send for Analysis" with the Subjekt "Connection Error".
[2021-10-04 18:24:55]
This log shows a successful connection:
SC/TT Futures Order Routing | Trading is supported. | 2021-10-04 20:09:31.815
SC/TT Futures Order Routing | Order cancel and replace is supported. | 2021-10-04 20:09:31.815
SC/TT Futures Order Routing | OCO Orders supported. | 2021-10-04 20:09:31.815
SC/TT Futures Order Routing | Bracket Orders supported. | 2021-10-04 20:09:31.815
SC/TT Futures Order Routing | Connected to server complete. | 2021-10-04 20:09:31.815
So you certainly do not have a problem connecting to the Sierra Chart Order Routing service.
[2021-10-04 20:05:41]
Yes thats right, but only when i reconnect after startup. Otherwise it does not work.
[2021-10-05 15:30:40]
We need to see the Message Log at the time there is a problem.
Reconnect to the data feed:
After about 10 seconds, provide a copy of the Message Log following these instructions:
