Date/Time: Sat, 01 Mar 2025 11:16:48 +0000
How to activate this line
View Count: 496
[2021-10-04 10:53:59] |
User942196 - Posts: 40 |
Hi a friend of mine has a line that follows the price and show it (Pic attached) I asked him how he did that But he does not know how he activated it in sierra (It is not a study) Can you help us? thanks |
Attachment Deleted. |
[2021-10-04 15:06:12] |
John - SC Support - Posts: 38292 |
Refer to the Current Price Line study: Current Price Line It looks like the line you are pointing to with an arrow could be from the Pivot Points study: https://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s87 Or, if that line is just $3.00 less than the Current Price, then you can create that line by using a combination of the Current Price Line and the Study Subgraphs Subtract. Refer to the information on the Arithmetic Studies here: Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
