Date/Time: Sat, 01 Mar 2025 11:28:43 +0000
Help with Speed calculation on the Zig Zag indicator
View Count: 527
[2021-10-03 22:34:58]
jsmanuse - Posts: 32
http://www.sierrachart.com/image.php?Image=1633300181429.png
I am trying to use the setting on this indicator to show the value for volume divided by length, however the value comes back as zero. Am I missing something?
imageScreenshot 2021-10-03 183147.jpg / V - Attached On 2021-10-03 22:33:00 UTC - Size: 457.23 KB - 188 views
[2021-10-04 14:12:31]
John - SC Support - Posts: 38292
What you are missing is that you first need to specify the Volume to Accumulate in the Input of this name above that setting. Once you set that volume, then the calculation for Volume/Length will work.
