Date/Time: Sat, 01 Mar 2025 11:16:51 +0000
Micro Symbols
View Count: 866
[2021-10-03 21:06:39]
wingz - Posts: 121
Will you please point me to the page that gives all the symbols for the eminis. I'm specifically looking for the Micro symbol for the ES
[2021-10-03 22:01:36]
John - SC Support - Posts: 38292
We can not do that, as it depends on the service that you are using as to what the actual symbol is.
Keep in mind that there is a Search function on the Find Symbol window where you could do a search for the word "micro" and go through all the symbols that have this word in their description. Refer to the following:
File Menu: Searching for Available Symbols
We can also tell you that the Micro ES has a symbol from the exchange of MES, which is what we use when you are using the SC Data - All Services service, as that uses the actual symbols that are used by the exchange.
[2021-10-04 03:49:36]
wingz - Posts: 121
I'll look in the find symbol window but......I use YOUR Denali feed for my Sierra charts.
[2021-10-04 14:33:31]
Even though you use our Denali Data Feed, the symbols are all different depending on your service setting. What is your Global Settings >> Data/Trade Service Settings >> Current Selected Service set to?
[2021-10-04 15:47:25]
wingz - Posts: 121
I found the symbol(MESZ21-CME) on the Find Symbol page and it's working on my charts. I didn't even know that page existed. I had never needed to use it before but, I'm glad I know it's there now. Thanks
