Date/Time: Fri, 18 Apr 2025 04:02:35 +0000
TPO initial balance
View Count: 1006
[2021-10-02 21:20:32] |
byohan - Posts: 2 |
Hello, On the FGBL market profile, is it possible to define the initial balance period between 8:00AM and 9:00AM? I also want it to correspond to the letters A and B on my chart. I can't find the option to do this.The only solution is to change the session times but I also want to keep the tpo that corresponds to the opening of the market until 8:00AM. Thanks in advance. |
[2021-10-03 20:09:55] |
John - SC Support - Posts: 39353 |
You can use the Custom Intraday Session Times to do what you want. Refer to the information starting at the following link and the 2 entries after it: Time Price Opportunity (TPO) Profile Charts: Number of Custom Intraday Sessions There is not a way to reset the lettering within the TPO for what you are wanting to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-03 21:57:51] |
byohan - Posts: 2 |
Thank you for the answer. Indeed it works with this method but I have two profiles instead of one and it is much less practical. Can we consider a future update that will allow to modify the start and end time of the initial balance to be taken into account for its calculation?
[2021-10-03 22:23:26] |
We have taken this as a Feature Request.
[2023-01-16 09:39:58] |
guy hervé banoho banoho - Posts: 2 |
Hello ,Team Support I would like to know if it's now possible to have a custom IB in just one TPO profile and no two like i have now. |
