Date/Time: Sun, 04 Oct 2026 18:15:50 +0000
Removing Trade Box from Trading DOM
View Count: 1685
| [2021-10-02 17:26:47] |
| User340810 - Posts: 9 |
Is there a way to remove the trade box from the DOM and only show price ladder? (see image). I want to remove whats circle in yellow in the image.
| [2021-10-03 00:52:40] |
| Tonkadad - Posts: 235 |
Have you unchecked the "Attach trade window to chart" option in the "Trade" menu at the top left of SC?
| [2021-10-03 03:01:28] |
Select M >> Close Trade Window on the trade window ( the window on the left) menu.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-03 03:01:43
| [2021-10-03 03:05:32] |
Can't hit the thank you button for some reason but thanks for the help. I was able to detach and then close it out as well.
| [2021-10-03 15:01:52] |
We will check on the thank you button functionality.
| [2021-10-03 19:27:04] |
| User90125 - Posts: 715 |
+1 Thank you. |
