Date/Time: Sat, 01 Mar 2025 11:12:05 +0000
Denali data feed Jigsaw rithmic
View Count: 1351
[2021-10-02 10:33:57] |
JanTheMan - Posts: 4 |
I have live account in amp and use rithmic and jigsaw daytrader for execution and wish it would stay that way. I have a question because I would like to use Sierra for analysis and also have access to the real data( denali). How to do it all? I should buy denali data straight away or you need to verify my account with amp first? Best regards Jan |
[2021-10-03 19:30:57] |
John - SC Support - Posts: 38292 |
First, you would go through the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* After that is all setup then you will need to make the connection to your live, funded futures trading account in order to validate the account for the CME Group. Since you will not be staying connected to that trading account, you will need to follow these instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees At Step #3 of the above, you need to connect to your trading service. In your case, since you are using Rithmic, you will follow these instructions to make that connection: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
