Date/Time: Sat, 01 Mar 2025 10:56:24 +0000
Overlay time based onto point and figure
View Count: 430
[2021-10-01 16:22:08] |
User900285 - Posts: 97 |
I have succeeded in overlaying a 15s chart onto a 10-1 pnf chart by unchecking "Match Source Bars to Destination Bars" in the settings of Study/price overlay. However when I try to overlay a numbers bars calculated values study which is on the 15s source chart, it will keep trying to change the source chart to the timeframe of the destination chart (10-1 pnf in this case). Is there any way to overlay every 15s numbers bars calculated values onto my 10-1 pnf chart? Thank you |
[2021-10-03 18:49:21] |
John - SC Support - Posts: 38292 |
You can NOT overlay a Numbers Bars Calculated Values study onto another chart. There is a way to get the information from another chart displayed in the Numbers Bars Calculated Values, but, as you are seeing, it only works for charts with the same timeframes and number of bars. Refer to the following information: Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart One option available, depending on which particular Numbers Bars Values you are wanting to overlay, would be to first use the Study Subgraph Reference to turn a particular value into a Standard Subgraph (not in a tabular format) and then overlay that Study Subgraph Reference to the other chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
