Date/Time: Sat, 01 Mar 2025 10:34:14 +0000
Activation of CFE denali feed
View Count: 524
[2021-10-01 15:28:54] |
Spinoza - Posts: 62 |
Have just activated CME denali and cfe denali. CME works fine but I have no CFE futures showing in the find symbol dialog box.
[2021-10-01 16:12:31] |
These symbols are not listed for Rithmic. For CFE, install another installation of Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Introduction Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "Ok" And then translate the symbols in your Chartbooks and Sierra Chart: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-01 16:12:48
