Date/Time: Sat, 01 Mar 2025 11:22:13 +0000
Night
View Count: 589
[2021-10-01 10:35:20] |
User657856 - Posts: 61 |
I have a question related to hours of play. I know that I can't play at night because I don't have enough capital. But how to count the night? Since when till when? And what time? Chicago or Polish? What happens if I play at night? Will you take my money right away? Kind regards Bogdan Date Time Of Last Edit: 2021-10-01 12:33:07
[2021-10-01 12:33:39] |
You need to contact your broker about these questions. If there are any issues with your charts not updating, then refer to this help topic: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-01 12:33:46
[2021-10-02 09:09:01] |
Good day. I asked the broker with this question and he replied that I should ask the Support Board about it. Kind regards Bogdan PS Glenn McBeth's answer from Infinity Futures is as follows: "These questions should go to support@transactfutures.com. Sincerely, Glenn McBeth Infinity Futures, " Date Time Of Last Edit: 2021-10-02 20:04:46
[2021-10-02 20:04:59] |
They gave you an email address to use. Not this Support Board.
