Date/Time: Sat, 01 Mar 2025 10:09:23 +0000
JPY-X Data Problem
View Count: 512
[2021-10-01 04:33:37] |
User486817 - Posts: 83 |
hello, i have a chartbook with all forex index daily charts. all chart data populates normally with the exception of JPY-X. after 2021-12-31 there is no daily data for some reason. intraday data is fine, but it begins 2021-09-01 creating a large gap. is there any way to resolve this? initially, i thought to update to the latest version, but the problem persists on version 2315. please advise and thank you. kindest, |
[2021-10-01 16:15:51] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And then follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-01 16:16:29
