Date/Time: Sat, 01 Mar 2025 10:02:27 +0000
I would like to try the interactive volume profile tool
View Count: 653
[2021-09-30 23:52:15] |
User668378 - Posts: 2 |
Hi, I would like to try the interactive volume profile tool. I believe you have to change something manually on my account - is that correct ? regards Marcin |
[2021-10-01 00:48:42] |
John - SC Support - Posts: 38292 |
Your information is not quite correct. The Draw Volume Profile tool is part of the Advanced Package for Sierra Chart. But, since you are on a Trial, you have full access to all of the Advanced Package features. Therefore, you can use the Draw Volume Profile Drawing Tool without having to change anything. For information on the tool, refer to the following documentation: Volume By Price Study: Draw Volume Profile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
