Date/Time: Mon, 10 Mar 2025 07:20:03 +0000
Make Risk/Reward tool have multiple targets
View Count: 748
[2021-09-30 21:19:10]
ElKimoBasha999 - Posts: 22
Hey there, if the risk/reward can have multiple targets would be sooooo useful, because in most trading situations we SCALE OUT at different points, so it would be really useful to just have it maybe have 3 targets or so. You could either define how many targets you want in the setting or it could be infinite until you press a certain key to say like thats it.
2nd Suggestion: Also it would be sooooo much more intuitive if the text lines would have the STOP at the bottom then ENTRY at the middle and Target at the top, as this follows the same order logic from bottom to top, as you have to click from the bottom first for your STOP then entry then target, so easier to read.
IF going short meaning the stop is up then entry is lower then target is lower, then the TEXT detail would follow the same vertical order.
THANKSSS
[2021-10-01 00:30:38]
John - SC Support - Posts: 38516
We have set this as a "Feature Request".
[2022-03-21 02:22:26]
chart_warrior - Posts: 96
Is there any progress on this?
