Date/Time: Mon, 21 Apr 2025 23:27:34 +0000
A keyboard hotkey to toggle lock/unlock ALL drawings on the active chart
View Count: 1247
[2021-09-30 20:57:01] |
ElKimoBasha999 - Posts: 22 |
Hey ya'll, I just want a way to assign a single keyboard hotkey to toggle to LOCK/UNLOCK all the drawings I have on my current chart. As I have tens of drawings everywhere, sometimes I can drag something by accident, and to right click and then allocate LOCK DRAWING is time-consuming for my trading style, and I have way too much to keep doing that and undoing that when I need to edit or move, just a simple lock and unlock hotkey would be magical! Thanks so much! |
[2021-10-01 00:27:27] |
We have set this as a Feature Request.
[2021-12-01 16:20:11] |
HumblyTrading - Posts: 201 |
I would also like to add that a hot key to change lock/unlock status for a single drawing would be helpful. Thanks |
[2022-03-25 17:06:44] |
Hello SC Team, Is this feature possibly on the roadmap for the next release? I use the lock/unlock all day long, and it would make the user experience much better if this could just be assigned to a hotkey on my mouse. Thank you for your consideration! Mike |
[2022-03-25 17:20:36] |
It is something that we would like to do, but we do not have any particular timeframe for it.
[2022-04-12 14:24:00] |
Hello SC Team, Does the application allow a custom programer to enable this feature or is that secured from the API? Thanks |
[2023-09-30 16:21:52] |
User619465 - Posts: 8 |
Greetings I would like to echo the significant benefit (time saver) having the ability to hotkey the lock / unlock drawing - would be Please Thank You |
[2024-12-12 16:01:53] |
lservin29 - Posts: 67 |
did lock/un-lock a chart drawing get added for hotkey capability? or only shortcut menu option _ I use this now: right click on chart and lock/unlock. would like to add it as hotkey. Date Time Of Last Edit: 2024-12-12 16:03:11
[2025-02-08 01:34:43] |
Hello SC Team, I'm curious to know if this feature of a hotkey might be added in 2025? Thank you, Mike Have a wonderful 2025! |
