Date/Time: Sat, 01 Mar 2025 10:40:40 +0000
How do I copy a set of indicators from one chart to another without deleting the existing
View Count: 895
[2021-09-30 20:06:51] |
User112372 - Posts: 7 |
How do I copy a set of indicators from one chart to another without deleting the existing set of indicators? I can see how save studies on a chart to a collection, but then if I try to put those indicators ALSO on another chart (as an Analysis) it deletes the existing set. Thank you.
[2021-09-30 22:41:55] |
Sawtooth - Posts: 4177 |
This is what I do: 1. Duplicate the chart. 2. Focus the duplicated chart and remove all studies except the ones you want to include in a study collection. 3. Check 'Prompt To Remove Existing Studies', give it a name, then Save All to a study collection of the remaining studies. 4. Remove the duplicated chart. 5. From the Analysis menu, apply the study collection to the other chart, then choose No when asked if you want to remove existing studies. Date Time Of Last Edit: 2021-10-01 12:04:27
[2021-10-01 00:45:44] |
John - SC Support - Posts: 38292 |
Refer to the information for Prompt to Remove Existing Studies when saving the Study Collection: Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-01 11:41:54] |
Do I apply the studied using "Analysis" Whenever I do all the studies on the previous chart are replaced automatically without prompting even though I chose the "Prompt to remove existing studies" option when I saved the collection. |
[2021-10-01 12:13:47] |
Never mind, now I understand. Thank you for your help! |
