Date/Time: Sat, 01 Mar 2025 10:38:57 +0000
a bit confused - to ADD denali to exsisting Realtime data feed
View Count: 655
[2021-09-30 16:58:43] |
HeyUgly - Posts: 251 |
hello want to ADD denali just the CME alongside the realtime data feed for equities. how exactly is this added. ive gone through alot of links not sure where tog o. Have package 5 currently. need to keep footprint data etc. |
[2021-09-30 17:02:41] |
package 11 it seems , thank you got it
[2021-09-30 17:04:08] |
John - SC Support - Posts: 38292 |
Yes, you are correct. But you need to go through the setup for the CME Group for the Denali Exchange Data Feed. Refer to the instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
