Date/Time: Sat, 01 Mar 2025 11:05:22 +0000
How to only display current Volume profile for TPO
View Count: 601
[2021-09-30 14:13:26]
User544395 - Posts: 15
I would like my chart to only display the current session volume profile in relation to the TPO. Below I have attached a photo to show.
imageVolume profile.png / V - Attached On 2021-09-30 14:13:12 UTC - Size: 334.12 KB - 177 views
[2021-09-30 16:16:51]
John - SC Support - Posts: 38292
You just need to change the number of days to load in the Chart Settings to 1. Refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad
[2021-09-30 18:57:29]
I still want to see the TPOs for the previous days though. I only want to erase the volume profile of the past days
[2021-09-30 23:31:18]
Then you would need to add a Volume by Price Profile that is not associated with the TPO and then set it as you desire. The main item you need to update is the Input for the Volume by Price for Based on TPO Chart. When you add a VbP to a TPO, it automatically assumes you want to base the VbP on the TPOs and sets this Input to Yes. You need to change it to No and select Apply, then you can change the rest of the Inputs as you need them. Refer to the information here:
Volume By Price Study: Based on TPO Chart
[2021-10-01 19:23:55]
Great I found it.Is there a way to have it reset every 30 minutes so I can see the volume of each period?
[2021-10-02 02:47:10]
You need to set the Volume Graph Period Type input to:
Volume By Price Study: One Period from Most Recent Period Start to End (One Period from Most Recent Period Start to End)
