Date/Time: Sat, 01 Mar 2025 10:02:59 +0000
orders are placed incorrectly
View Count: 580
[2021-09-30 13:33:55] |
Пользователь488020 - Posts: 100 |
Hello! Explain to me why when I call a limit order, the program gives me a stop order? How to solve this problem? I attach the drawing.
[2021-09-30 13:40:37] |
The Order Type setting on the Trade Window only applies when using the Buy or Sell buttons at the very bottom of the trade window. How was this order entered?
[2021-09-30 16:22:45] |
I entered the order through the chart on the bid side of the orders by calling the order with the right mouse button.
[2021-09-30 17:02:29] |
John - SC Support - Posts: 38292 |
Then refer to how you have these settings set: Global Trade Settings Windows: Chart DOM Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
