Date/Time: Tue, 22 Sep 2026 22:32:33 +0000
Package Selecting For REAL-TIME data for Stock & Market Profile
View Count: 1046
| [2021-09-30 09:29:59] |
| DreamGreeneIII - Posts: 2 |
Hey I was told you guys are the best but when I got here, I became very confused as to what I needed. 2 days into doing research to figure out if this is what I was looking for, I finally came to the conclusion that I think it is.. just a little more expensive than I was lead to believe. But anyway from what I’ve researched I believe I need: 1.)Package 5 $36, 2.)U.S. equity data $10.5, 3.)And real-time data $25?? My goal is to be able to use your market profile charts on stocks and have it on 1 screen while I use my TD ameritrade account to trade stock options on my other screen. 1.)I NEED the charts to be accurate and fast. 2.)Also I need to be able to see historical AND REAL-TIME intraday market profile charts for the stocks. 3.)I want to be able to customize how I want my market profiles to look. 4.)I need to be able to customize my timeframes & zoom in&out without the data getting messed up. 5.)I also need to be able to separate overnight and open market profiles. A video I watched said I’d have to update my charts every few secs manually, but someone told me that wasn’t true. I just need to know if I’ll be able to do those functions I listed above and hopefully more? If so, is what I believe I said I need in the 1st paragraph the most accurate and cost efficient way to accomplish this my goals?? If you guys could respond ASAP that’d be appreciated! |
| [2021-09-30 09:31:34] |
Also for some reason my free trial ended a couple hours after I signed up? Could you help me with that too?
| [2021-09-30 14:48:32] |
| John - SC Support - Posts: 47980 |
Your trial has been reset, so you are all set there. It looks like you got caught by our trial analyzer, which we use to catch people that try to get multiple trial accounts in order to not pay for Sierra Chart. The setup you describe is what you will need for right now. This will get you the U.S. Equities data as part of the Sierra Chart Exchange Data Feed and Package 5 gives you access to the TPO profiles. You do not need recalculate your charts every few seconds to get the TPOs to update. We have no idea where that information is coming from. The charts will update automatically as the day proceeds. ---------------- Note that we are working on a new NASDAQ data feed in order to get the U.S. Equity data. Once that is available, it will be part of the Denali Exchange Data Feed. Keep an eye on this thread for updates: Upcoming Data Feed Plans 2, New Exchange For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-30 14:50:31
