Date/Time: Sat, 01 Mar 2025 10:31:50 +0000
connection to Denali data feed exchange questions
View Count: 501
[2021-09-30 07:27:38] |
User278398 - Posts: 291 |
hello, 1. i change my packge to be 11 (Advance + Denali data feed ). and now i wondering if i can get real time for stocks? or i need to active/buy more things to open this real time for them * pic(1) is attached. 2. with "Denali data feed" can i get market depth for stocks? 3. what i need to choose from "data/trade service settings" to connect denali data feed ? many thanks. |
[2021-09-30 09:12:01] |
The Denali Exchange Data Feed at this time does not provide real-time stock data. You need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed You are already using the Sierra Chart Exchange Data Feed for real-time US equities data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-30 09:12:32
[2021-09-30 09:37:46] |
so, i dont realy need pack 11 (46$) (because i dont get there real time for stocks+ i cant see "numbers bars" study work well) ? instead for real time + using "numbers bars" study i just need package 5 (36$) and subscribe "u.s equitie(10.5$) ? regards. |
