Date/Time: Sat, 01 Mar 2025 10:37:26 +0000
Editing Candle Overlay Hiegth
View Count: 742
[2021-09-30 02:42:45]
User340810 - Posts: 9
Is there a way to change the height or scaling of the candle overlay study to include the entire footprint bar. For example, see how on opening and closing levels the candle overlay outline cuts through the bid x ask volume. Is there a way to make sure the candle overlay includes the entirety of the footprint bar?
imageExample.png / V - Attached On 2021-09-30 02:42:02 UTC - Size: 104.26 KB - 226 views
[2021-09-30 09:18:22]
We are not sure what study you are using. The proper way to show a candlestick outline is to use this study Input:
Numbers Bars: Open and Close Marker Style
[2021-09-30 12:51:45]
I am using numbers bar for footprint and Overlay (bar) for candlestick. I prefer it this way for visualization purposes. Is there a to fix this problem?
[2021-09-30 16:08:47]
John - SC Support - Posts: 38292
What it is showing is correct. Those are the prices at which the open and close occur. If they were offset, then you would not be able to tell exactly what price they matched to. The only other option would be to use a narrow bar and put it between the Bid and the Ask.
