Date/Time: Sat, 01 Mar 2025 10:02:32 +0000
Sierra chart
View Count: 526
[2021-09-29 21:33:40]
User862725 - Posts: 1
How do I get Sierra chart to work with amp futures
[2021-09-30 00:03:02]
John - SC Support - Posts: 38292
If you have an account with AMP, then they would have set you up with your order routing through either Rithmic or CQG. Depending on which one you are setup to use, you will need to follow the appropriate Setup Instructions.
For Rithmic, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
For CQG, follow these instructions:
CQG Trading Platform Service: Setup Instructions
