Date/Time: Sat, 01 Mar 2025 08:55:02 +0000
es# daily
View Count: 402
[2021-09-29 18:05:38] |
User804571 - Posts: 1 |
How can I open a daily ES contract? Manages to open only for a contract for that month (ESZ21). Thanks |
[2021-09-29 18:26:06] |
John - SC Support - Posts: 38292 |
We are not sure exactly what you are asking, so we will give you a couple of answers, hopefully one of these is what you need. First, if you do not know how to open a daily (historical) chart, then refer to the following: Getting Started, Opening Charts and Basic Trading: Open A Chart Second, if you can open the chart, but you want to see more historical data than just the current contract, then you need to use the Continuous Futures Contract option. Refer to the information here: Continuous Futures Contract Charts And finally, if you are wanting to open a chart for a different (previous) contract, then you just need to type in the contract that you want to open the data for. For example, to see the December 2020 ES contract, you go to Find Symbol and type in ESZ20-CME (actual entry may vary depending on your Service setting). refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
