Date/Time: Sat, 01 Mar 2025 10:39:09 +0000
Denali
View Count: 571
[2021-09-29 17:08:38]
Dennis B. - Posts: 286
When I go to make the Denali switch this Friday, do I use the "Rithmic Direct Dtc" or the "Rithmic Trading". Little confused. Had quite a bit of trouble last month.
[2021-09-29 17:50:29]
John - SC Support - Posts: 38292
We are not sure what you mean by the "Denali switch", but in terms of Rithmic, you need to be using the new Rithmic connection (Rithmic Direct DTC). The instructions to get setup using this connection is at the following link:
Rithmic Trading Platform Service: Setup Instructions
[2021-09-29 19:02:16]
Ok..so from now on I use the (Rithmic Direct DTC) instead of the (SC Data-all services) and the (DTC-Sub Instance) for my Data/Trade Service Settings. Is that correct ? Before, once at the first of the month I had to switch from SC data to Rithmic and
then back again. It was a bit of a pain and half the time there was a glitch. Other than that, SC has been great for me.
[2021-09-29 19:08:26]
Wait a minute, can I just stick with SC for data and forget about Rithmic. Your data is solid, rather not switch unless forced.
[2021-09-29 23:27:15]
Sorry, we did not understand what you were needing to do.
Unfortunately, you still need to make the connection to your live, futures trading account in order to validate your Non-Professional status for the CME Group. Therefore, you will need to make the connection to Rithmic. As noted above, you will need to follow these instructions to connect to Rithmic this time, which will be different from before due to the new interface:
Also, if you did not know, you can view the verified date for your account at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2021-09-30 12:50:09]
So do I have to upgrade to ver. 2315... running ver. 2299 right now ?
[2021-09-30 15:36:32]
We would definitely recommend it, in order to ensure that you do not have any issues with the new Rithmic connection.
