Date/Time: Tue, 29 Sep 2026 04:50:21 +0000
Horizontal Grid Alert
View Count: 792
| [2021-09-29 16:16:26] |
| quin6 - Posts: 22 |
Wishing you well this Wednesday. Is one able to reference the Horizontal Grid Lines to Alert a sound when a horizontal grid line is hit? Thanks. |
| [2021-09-29 16:40:28] |
| John - SC Support - Posts: 48044 |
Sorry, no, those are not available in Alerts. You would need to use either a Horizontal Line drawing or the Horizontal Lines study to create the lines you want at the levels you want and then reference those. Refer to the information here: Study/Chart Alerts And Scanning: Referencing Chart Drawings and here: Horizontal Lines Also, there is the Symbol Alert, which can be used to get an alert at a particular price. Refer to the following: Alerts Manager: Symbol Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
