Date/Time: Tue, 04 Nov 2025 17:02:49 +0000
Server-side OCO and Bracket Orders - Rithmic DTC
View Count: 2220
[2021-09-29 14:03:34]
User968625 - Posts: 260
quick question about the server-side orders with Rithmic DTC. having some troubles with the internet so wanted to check if the server-side orders work with the Rithmic DTC connection
Thank you
[2021-09-29 14:09:32]
We do not know but we can tell if you provide us the message log as explained below.
Reconnect to the data feed:
After about 5 seconds, provide a copy of the Message Log following these instructions:
Date Time Of Last Edit: 2021-09-29 14:42:12
[2021-09-29 14:40:37]
I don't have a problem now (I think I just had an internet connection). I am just asking if the server-side orders are supported with a Rithmic DTC connection. I wanted to make sure if there is an issue I have this backup plan for my orders. sorry for the confusion
[2021-09-29 14:42:00]
We do not know. We can only tell by looking at the Message Log.
[2021-09-29 14:59:17]
ahhh, got it. here is the log
Software version: 2284 64-bit | 2021-09-29 10:56:11.916
(message log removed)
Date Time Of Last Edit: 2021-09-30 10:28:19
[2021-09-30 10:28:39]
Sierra_Chart Engineering - Posts: 21306
In this case server-side OCO orders are supported but not server-side bracket orders.
[2021-09-30 15:14:55]
This log shows that server-side OCO orders are supported:
Rithmic Trading | OCO Orders supported. | 2021-09-29 10:56:50.348
But not bracket orders.
[2021-09-30 16:11:56]
ok, To make sure I am using the right terms:
1- a bracket order, which is not supported, is when you have a target and stop
2- OCO, which is supported, is explained here (Attached Orders: Attached Orders Examples) sounds the same.
3-Or is the OCO order is when you have a buy entry and sell entry and one of them entres the other is canceld
I am a little confused here. if it is the case that my stops, that's what I am worried about, is not on the OCO server then can I use a VPS virtual Server to work with that DTC Rithmis as you explained here (Attached Orders: Using DTC Server Feature for Reliable Server Side Attached Orders)
[2021-10-06 15:19:36]
What is not supported, is the full management of the parent and child OCO on the server.
Once the parent order fills, the child orders will be in an OCO group managed on the server.
Date Time Of Last Edit: 2021-10-06 15:20:07
