Date/Time: Sat, 01 Mar 2025 08:26:18 +0000
Cancelling entry limit order if target was reached first
View Count: 441
[2021-09-29 08:18:56] |
User252279 - Posts: 9 |
Scalping the ES, a day with high volatility. Sent an entry limit order (with SL and target attached). In a second, prices reached the scalping target (before filling my entry order). The next second, prices reversed and filled my entry order and then hit my SL. I always cancel an entry limit order if prices reached the target before filling it. This time, however, all occurred in a couple of seconds, faster than the time it takes to click on the X to cancel it. Is there any way to automatically cancel an entry limit order if prices reached the target order first? Or cancel the entry limit order if prices moved away a certain amount of ticks? Your help is much appreciated. |
[2021-09-29 12:06:12] |
No, this is not supported.
