Date/Time: Sat, 01 Mar 2025 07:53:13 +0000
Delta by Price (DbP) button and Volume by Price (VbP) Button on Control Bar
View Count: 743
[2021-09-29 03:19:08] |
OrbitalD - Posts: 29 |
Hi, I have a VbP button on my Control Bar and I can change it to DbP if I open the Delta VbP study and make it the default but I would like to have both DbP and VbP buttons without having to go into the studies and change the defaults. Is that possible? Thanks! |
[2021-09-29 14:08:22] |
John - SC Support - Posts: 38292 |
You would have to do what you want using Study Collections. Refer to the information at the following link, which also has a link to Control Bar buttons for Study Collections at the top: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
