Date/Time: Mon, 10 Mar 2025 01:55:08 +0000
Is there a way to hide the Price Values when using the Risk & Reward Tool?
View Count: 972
[2021-09-28 22:38:11] |
HumblyTrading - Posts: 192 |
Hello, I would like to use the Risk & Reward Tool to simply show the Ticks and RR, without showing the price as it can be a bit cluttered on the chart having to display the price. Is there a setting to turn off the Price display? Thank you, Mike http://www.sierrachart.com/image.php?Image=163286853353.png |
[2021-09-29 00:02:59] |
John - SC Support - Posts: 38516 |
There is not an option to do this. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-28 20:02:32] |
Hello SierraChart, I use this tool frequently as a way of planning stop loss placement and take profit placement in terms of ticks. It would definitely be much more useful if we could hide the price data, which causes clutter on the charts, when the data is not needed. Thank you for setting it as a feature request. May I ask if this feature will likely be added within the next few months? Thank you again, Mike T |
[2021-11-29 17:09:27] |
We do not know when we will be able to get to this or any other Feature Request. There are just a lot of factors that affect when it might get done.
[2022-03-17 14:59:48] |
Hello SC Team, I would like to put in another request for this feature, the ability to use the Risk Reward Tool without having to see the price values or the words "Entry," "Stop" or "Target", which are mostly clutter. For example, if I want to Mark only the distance in ticks, It would be so much cleaner to use the RR tool with only the actual tick distances showing. Traders could then use this tool to mark up every trade or missed trade on a chart, without too much clutter. Thank you for your consideration! Mike |
