Date/Time: Mon, 21 Sep 2026 15:02:43 +0000
Denali and CQG
View Count: 872
| [2021-09-28 07:52:22] |
| Botond Hites - Posts: 1 |
Greetings Sierra Charts! I have just setup the Sierra Charts platform with my AMP CQG account. I have opted to go with the Denali data feed as well. I am a bit new to this and wanted to make sure that my fee's per side will not be charged on both data feeds, CQG and Denali. I have gone through the website multiple times, but might have missed the answer. Thank you for your help All the Best, Bo |
| [2021-09-28 15:45:03] |
| John - SC Support - Posts: 47941 |
Since you are using the Denali Exchange Data Feed, you will need to tell AMP to not charge you for the CQG data feed. -------------- We notice that you have the Sierra Chart Exchange Data Feed active, but you have not selected any exchanges. Is this still in process, or did you make a mistake activating this data feed? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-29 15:39:32] |
We went ahead and deactivated the Sierra Chart Exchange Data Feed on your account since you do not need that. The Denali Exchange Data Feed remains active still. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-29 15:39:43
