Date/Time: Sat, 01 Mar 2025 08:24:23 +0000
Futures data not coming through
View Count: 597
[2021-09-27 23:22:03]
User216169 - Posts: 17
Just want to know if there are any issues today with data from CME coming though.
I am on the MES ticker and there is no data.
I have not changed any of my settings. Allow support for Sierra Charts data feed is enabled.
Private File
[2021-09-27 23:46:33]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-09-28 07:20:46]
This is the problem:
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-09-28 02:28:16.236
Refer to:
Denali Exchange Data Feed: Connections (Connections)
Date Time Of Last Edit: 2021-09-28 07:21:25
[2021-09-28 07:52:39]
Thanks,
I was only running one instance when having this issue.
Either way, I have followed the above instructions but I still don't have any data.
Any ideas?
[2021-09-28 08:20:41]
I have tried a few things, When I connect to interactive brokers service I don't get any market depth. Because I have to turn off 'all support for sierra shart data feeds' to get any data.
The only way to get full market depth is through SC data-all services with 'all support for sierra shart data feeds' disabled. There is still [M] showing after the ticker name.
This is with only using one instance!
[2021-09-28 08:28:25]
Please see images
Private File
Private File
Private File
[2021-09-28 13:00:11]
It is not clear why there is a problem, but it might be related to a recent change. We are going to revert that and have a new release out in about 15 minutes.
You definitely should not have any trouble with one instance. That really makes no sense at all.
Date Time Of Last Edit: 2021-09-28 13:00:25
[2021-09-28 13:18:52]
The problem is Sierra Chart not being able to connect to the Denali Exchange Data Feed because of a connection limit.
We have put out a new prerelease now.
Update to the latest prerelease following these instructions:
Let us know if you still have any further issue.
Date Time Of Last Edit: 2021-09-28 13:19:18
[2021-09-29 08:05:23]
Thanks,
That worked.
