Date/Time: Sat, 01 Mar 2025 08:10:43 +0000
New account setup
View Count: 450
[2021-09-27 16:04:44] |
User918024 - Posts: 1 |
Hello, I have had a Sierra account in the past, now expired. Not looking for a free trial, just want to connect with a different broker. I'm still waiting for confirmation on the funds being transferred. Will be trading just the CME futures, as a non-professional. Question 1 , do I wait for funded account confirmation before selecting data package ? I think it will be #11 w/Denali feed Question 2 , can I switch from live to Sim trading from time to time? Thank you |
[2021-09-27 18:01:45] |
John - SC Support - Posts: 38292 |
1) You will need to wait for your trading account information in order to setup the Denali Exchange Data Feed, as you will need to enter the account information into the agreements for the Denali Exchange Data Feed. When you are ready to setup the Denali Exchange Data Feed, then go through the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* But, you can select your base package and get started using the system now if you want. If you think you will eventually be on package 11, then choose Package 5 for now and the instructions for the Denali Exchange Data Feed will tell you when to change to Package 11. 2) Yes, you can switch between Sim and Live mode at any time. Refer to the following: Trade Menu: Trade Simulation Mode On (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
