Date/Time: Sat, 01 Mar 2025 08:19:23 +0000
up / down tick volume
View Count: 1055
[2021-09-27 13:49:04]
AKR - Posts: 524
is there a study showing the up and down tick volume in one bar? like the volume bar, just divided in uptick and downtick that add up to total volume?
[2021-09-27 16:58:10]
John - SC Support - Posts: 38292
Attached is a Study Collection that will display the Up/Down tick as a single bar with the down tick being negative values and a different color. Refer to the following for how to use a Study Collection:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
attachmentUp-DownTickSingleBar.StdyCollct - Attached On 2021-09-27 16:58:07 UTC - Size: 61.5 KB - 816 views
[2021-09-27 17:44:06]
AKR - Posts: 524
thx. why can not be both positive values. with diff color?
[2021-09-27 18:29:10]
There is not a way to display them next to each other in Sierra Chart (basically, only 1 data point per bar is allowed). You can use the Up Tick Volume and Down Tick Volume studies separately and see them in different regions, but not in the same region unless you do what we gave you in the Study Collection.
