Date/Time: Sat, 01 Mar 2025 08:52:48 +0000
When I scroll through DAILY bars, the smaller time frames update, I want to DISABLE that
View Count: 516
[2021-09-27 12:46:44]
ElKimoBasha999 - Posts: 22
Hey there,
So if I have multiple charts open on same screen, and same symbol, as I scroll through the DAILY with my cursor (which is set to Chart Val+Hand)it automatically makes all the smaller time frame charts (30minutes, 5minutes) like automatically change the LAST price of the DAILY bar that my mouse is scrolling to, I want to DISABLE THAT.
I want to freely scroll with my mouse over the daily bars without it changing anything from 30 or 5minutes.
Here is a screenshot:
THANKS
imageScreen Shot 2021-09-27 at 5.40.47 AM.png / V - Attached On 2021-09-27 12:45:54 UTC - Size: 540.29 KB - 154 views
[2021-09-27 16:15:03]
John - SC Support - Posts: 38292
Refer to the settings starting at the following link and the 4 sections after it:
Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
