Date/Time: Sat, 01 Mar 2025 07:05:13 +0000
Multiple Chartbooks Live/Sim trading
View Count: 402
[2021-09-27 11:38:57] |
User377189 - Posts: 203 |
I have multiple chartbooks open and would like to trade some chartbooks in live market and others in sim mode, how can i set this up? Currently when i go to tab Trade --> and uncheck the Trade Simulation Mode On all chartbooks go off SIM MODE |
[2021-09-27 12:16:57] |
This is not supported within a single instance. But you can use separate instances of Sierra Chart configured as you require to accomplish this: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
