Date/Time: Sat, 01 Mar 2025 07:58:07 +0000
Exchange-Traded Spreads basic questions
View Count: 797
[2021-09-27 11:02:29] |
User893396 - Posts: 40 |
Hello, I am using Denali Exchange Data Feed (Full CME Group with Market Depth for NP Package) with CQG WebAPI routing and a trading account at AMP Futures. I would like to trade CME Exchange-Traded Spreads (like for instance GEZ21-GEH22.FUT_SPREAD.CME) When I open a DOM with this symbol I first get this message: "Symbol is Unknown. Click for informations. Requested Symbol was not found." But after a few seconds, the message disappears and I can see a DOM that is apparently working. Before I wrote this post, I have contacted AMP Futures and asked them about fees, margins, etc... for spreads but they just said I should use TT platform for Spreads... Is it possible to trade CME Eurodollar Exchange-Traded Spreads with Sierra Chart/Denali/CQG WebAPI/AMP Futures? How is it working exactly? If not, what would be my best option? Do you know by any chance where can I find relevant informations about commissions, fees, margins, etc...? Thanks for your help |
[2021-09-28 14:41:08] |
Yes what you want to do is supported. Open a chart for GEZ21-GEH22.FUT_SPREAD.CME or whatever spread symbol. And then in the Trade and Current Quote Symbol field in Chart >> Chart Settings Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) You need to use the CQG spread symbol: CQG Trading Platform Service: CQG Exchange Traded Strategies/Spreads Symbol Format And enable this setting: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) This is not something we are able to help with: Do you know by any chance where can I find relevant informations about commissions, fees, margins, etc...?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-28 14:47:22
[2021-09-28 14:44:48] |
Post above has been corrected.
