Date/Time: Sat, 01 Mar 2025 08:02:42 +0000
Connection with AMP futures as a broker
View Count: 677
[2021-09-27 06:15:04] |
User552931 - Posts: 25 |
When I try to connect AMP futures as a data server and my broker account to the Sierra Chart program does not give me the option in the servers menu. In File -> Data adjustment service AMP Futures does NOT appear as a connection possibility. In the AMP Futures video tutorial if it appears: https://www.youtube.com/watch?v=B-bGx6yIlF0&ab_channel=AMPFutures |
[2021-09-27 15:27:08] |
John - SC Support - Posts: 38292 |
There is not an option for just AMP. In the video they point out that there are 3 options available: Rithmic, CQG, and AMP TT. The AMP TT is no longer supported and has not been for a long time. Therefore, you should be setup for your order routing with AMP using either Rithmic or CQG. Depending on which one you will follow the appropriate Setup Instructions. For CQG: CQG Trading Platform Service: Setup Instructions For Rithmic: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
