Date/Time: Sat, 01 Mar 2025 07:04:43 +0000
Colour ZigZag line HH HL
View Count: 591
[2021-09-26 18:53:23] |
User97684 - Posts: 136 |
Hi, PLs hlp - is there a way to colour the Zig Zag line in accordance with the trend as set by the HH & HLs Many thanks |
[2021-09-26 20:59:39] |
John - SC Support - Posts: 38292 |
You can change the color of the Zig Zag lines based on their slope, so you can have one color for down-sloping and another for up-sloping, but it is not possible to set the color based on the trend type. Refer to the following for setting the Auto-Coloring of a Subgraph (ZigZag - Subgraph 1 in this case): Chart Studies: Subgraphs Tab >> Auto Coloring For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
